gaganailawadi Posted July 13, 2018 Share Posted July 13, 2018 (edited) Greetings from India. I would be happy if anyone can help me building my workstation. with having budget of 2000$. my main work area is on 3d arch viz & Rendering in vray & corona. ( vray is hybrid can utilize GPU + CPU ) & Corona is CPU based). i am pretty noob in hardware stuff.i dont play games. CPU- ryzen 2700x or should i go for Thread Ripper 1920x ? GPU - 1070ti ? or does quadro have major difference in rendering ? ( quadro p4000) Ram - gskill ripjaw or trizent z 64gb 3200 mhz ssd - samsung 970 evo hdd - 2tb x 2 what cooler or fan should i use ? case ? Edited July 13, 2018 by gaganailawadi Link to comment Share on other sites More sharing options...
Nikolaos M Posted July 21, 2018 Share Posted July 21, 2018 Wait for a month or so, for the new Threadrippers gen 2.0 to come out. I'm sure that TR1 and Intel's i9's prices will be compressed even more. Link to comment Share on other sites More sharing options...
gaganailawadi Posted July 23, 2018 Author Share Posted July 23, 2018 Wait for a month or so, for the new Threadrippers gen 2.0 to come out. I'm sure that TR1 and Intel's i9's prices will be compressed even more. Thanks for the reply. So should i go with he TR 1920x ? Link to comment Share on other sites More sharing options...
Nikolaos M Posted July 24, 2018 Share Posted July 24, 2018 With the TR 1920X, 64gb RAM 3200MHz, and a 1060 6gb at minimum, you'll need to raise your budget a bit. PCPartPicker part list Link to comment Share on other sites More sharing options...
abhinavmathur Posted September 14, 2018 Share Posted September 14, 2018 Hey since you are from India you can consult many system integrators like Ant PC for the perfect solution, if you are not into DIY. If you are I would suggest you: CPU- ryzen 2700x or should i go for Thread Ripper 1920x ? ---- > Go For Threadripper GPU - 1070ti ? or does quadro have major difference in rendering ? ( quadro p4000) ----> Quadro is more reliable and professional applications centric but are expensive. Ram - gskill ripjaw or trizent z 64gb 3200 mhz ------> Overkill it is You can easily go for G.Skill Ripjaws V 2400 Mhz ssd - samsung 970 evo --- > How much memory? Again 970 Overkill save your money and go for 860 hdd - 2tb x 2 --> Go for WD HDD what cooler or fan should i use ? case ? ---- ? If you are going for 2700X Stock is good and for Threadripper Cooler Maser ML240L and for Case if you can opt for Cooler Master H500P Hope this helps.. if you have already purchased the system do share with us your build images. Link to comment Share on other sites More sharing options...
