thomasmiller Posted September 25, 2018 Share Posted September 25, 2018 I was wondering if anyone else was running into this issue and if there's a solution/workaround. I updated from 3Ds Max 2016 to 2019 and it seems nearly impossible to select V-Ray lights and Forest Pack objects. I didn't have this problem with 2016. Now I have to either use a selection filter to select the lights and cycle through every single object that is behind a Forest Pack object in order to select it. Appreciate the help! Link to comment Share on other sites More sharing options...
