That realistic feeling
nitastefan
Hi there! So i start rendering a while ago but there is one problem that troubles me, and that is the studio render result i get from my renders. As far as i know, the problems seems to be that i put too much light in the scene, but i might be wrong so i will leave here some RAW renders with the settings i used and maybe if you have a few free minutes, you can take a look.As for the desire look or something in that way :)) is that industrial office render. I want to point out if i use find and bind script and use dome light with sun and hdri map to the dome light with same windows vray light plane( different value ofc) i get the same studio effect. Right now i did not find any good method for skylight portal lights.Every single time i use skyligh portal there is so much light till half room and the other half is almost black. Thank you!
3ds max 2017, v-ray 3.6
Settings:
V-ray sun
-Size multiplier=15
-Intensity=0.2
Window vray light plane
-intensity=50
-invisible=checked
-affect reflections=not checked
Bulb sofa light
-intensity=500
-invisible=checked
Ceiling light
-intensity=200
-invisible=checked
Physical Camera
-Aperture=6
-Type=1/seconds
Duration=20
Iso=100
