milicastojanovic1 Posted November 29, 2018 Share Posted November 29, 2018 Hi, i have white spots instead of light, i used vray plane, but there is not light pattern at all, just some little spots on the place where should be light. i tried on some other scene and it was okay, but in this scene i cant figure out whats wrong. can someone give me some directions what should i try? Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted November 29, 2018 Share Posted November 29, 2018 Could you post some screenshots of your scene setup? also rendering settings. it is very hard to debug without more information. Link to comment Share on other sites More sharing options...
TomD_Arch Posted December 2, 2018 Share Posted December 2, 2018 There a literally so many things that could be causing this, I have to agree with Francisco above, this is probably an instance where we would need more information to help. It could be the materiel that the light is reflecting off of behind it, it could be the GI settings, but it may also be the light setting itself. Have you tried deleting the light from the scene and creating a new one? Maybe use a material override and turn everything a medium gray? Link to comment Share on other sites More sharing options...
milicastojanovic1 Posted December 2, 2018 Author Share Posted December 2, 2018 http://tinypic.com/r/n3k8br/9 http://tinypic.com/r/2quqfk3/9 http://tinypic.com/r/1zq35mt/9 It was worse, but I changed some setting and its better, but not good as should be. Link to comment Share on other sites More sharing options...
Casey Hawley Posted December 3, 2018 Share Posted December 3, 2018 Is the light inside geometry, or possibly right on the edge? Or maybe it's those tiny omni lights at the ends of the lights. Basically, you don't want the point of emission (the very center of the light) to be inside geometry, or snapped exactly to a face. Also, your render settings look non-standard, especially the Light Cache settings. If your light positioning is good, reset the render settings to default. Link to comment Share on other sites More sharing options...
