joshsnz Posted December 21, 2018 Share Posted December 21, 2018 Render: V-Ray 3.6 Engine: CUDA When using the CPU engine the option "Use local subdivs" is right there under DMC sampler, but whenever I switch to the CUDA engine that option is no longer there, it completely disappears. Therefore while on CUDA, my reflecion / lighting sampling is greyed out. If I enable use local subdivs while on CPU engine and I switch to CUDA, sampling is no longer greyed out. So I add reflections to my render elements, I leave my material reflection samples at 8, that render pass comes out noisy, I increase the sample to 256, not a single difference, therefore it was just a visual bug. TL;DR: How do I enable "Use local subdivs" on the CUDA engine if that option disappears completely? Link to comment Share on other sites More sharing options...
