hoseinasadi Posted December 30, 2018 Share Posted December 30, 2018 Hi, Im trying to setup a custom shot from which the camera view is limited to my desired preference. I somehow managed to limit the vertical shot in render setup, however I cant make it work horizontally. In the picture Ive illustrated how Id like my shot to be: Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted December 31, 2018 Share Posted December 31, 2018 Just use a region. In the drop down under "Area to Render" is an option for Region and it gives you visual feedback in the viewport to adjust the area being rendered. Alternately you should be able to smooth out your current aspect ratio to a 2:1 and just half the the Width and double the lens. Unless you are using vertical shift in your camera. Render 1200px by 600px with a 24mm lens. Then render 600px by 600px with a 48mm lens. They should be exactly the same only one see more in the width. Again, unless you are shifting your camera in the perspective controls. Link to comment Share on other sites More sharing options...
heni30 Posted January 1, 2019 Share Posted January 1, 2019 Use the Overscan script. It's mostly used to add image but it will subtract as well. It's been a life saver many times. If you want a low tech solution just put in some black walls on the 2 sides right in front of the cameras and adjust to your liking. Link to comment Share on other sites More sharing options...
hoseinasadi Posted January 1, 2019 Author Share Posted January 1, 2019 heni30 said: Use the Overscan script. It's mostly used to add image but it will subtract as well. It's been a life saver many times. If you want a low tech solution just put in some black walls on the 2 sides right in front of the cameras and adjust to your liking. Thanks a lot!! Link to comment Share on other sites More sharing options...
