SgWRX Posted February 4, 2019 Share Posted February 4, 2019 undo on (For obj in selection do obj.scale *= (random 1.0 1.75)) if i paste that into the listener window and hit it works great! i created a macroscript button (i have a custom tool bar and created a button for this) and it leaves me with objects that are either 100% scaled or 200% scaled. what the? any help appreciated! macroScript RandomScale category:"Steve" tooltip:"Random Scale" undo on (For obj in selection do obj.scale *= (random 1.0 1.75)) Link to comment Share on other sites More sharing options...
SgWRX Posted February 5, 2019 Author Share Posted February 5, 2019 well. i got it to work. macroScript RndScale category:"DragAndDrop" toolTip:"" ( (undo on (For i in selection do i.scale *= random .9 1.75)) ) Link to comment Share on other sites More sharing options...
neil poppleton Posted February 5, 2019 Share Posted February 5, 2019 very useful Link to comment Share on other sites More sharing options...
SgWRX Posted February 5, 2019 Author Share Posted February 5, 2019 thanks. i finally did a bunch. it seems pretty darned hard to manage custom toolbar buttons and even the user manual on setting up utility buttons didn't work. i didn't want to waste anymore time on this this morning, but at least got this far. bummer that it auto-creates "drag and drop" category and it names them all Macro 1 and Macro 2 etc... then you have to go find those files in windows obscura edit and re-drag and drop. ugh autodesk really irks me when it comes to UI design. Link to comment Share on other sites More sharing options...
SgWRX Posted February 5, 2019 Author Share Posted February 5, 2019 ok so here are the ones i added today: this one flattens spline in z-axis Quote macroScript FlattenSpline category:"DragAndDrop" toolTip:"" ( on isEnabled return ( selection.count == 1 and \ (classof selection[1] == SplineShape or\ classof selection[1] == Line) \ and selection[1].modifiers.count == 0 ) on execute do ( new_z = $.pos.z for s = 1 to (numSplines $) do ( for k = 1 to (numKnots $ s) do ( knt = getKnotPoint $ s k in_vec = getInVec $ s k out_vec = getOutVec $ s k knt.z = in_vec.z = out_vec.z = new_z setInVec $ s k in_vec setOutVec $ s k out_vec setKnotPoint $ s k knt )--end k loop )--end s loop updateshape $ )--end execute )--end script this one changes the color of the backface lines of geometry when you are in a UI scheme with a medium grey viewport background. Quote macroScript BackFaceLineColor category:"DragAndDrop" toolTip:"" ( NitrousGraphicsManager.DarkerEdgeOption = #off ) this is random z-rotation Quote macroScript RandomZRotation category:"DragAndDrop" toolTip:"" ( (undo on (For i in selection do i.rotation.z_rotation = random 0.0 360.0)) ) get rid of materials on selected objects Quote macroScript NullMaterial category:"DragAndDrop" toolTip:"" ( ($.material=null) ) this one helped me place 5 different trees randomly everywhere there was a dummy helper objects who's name starts with Dummy. the dummy objects were RPC in revit and came into max as dummy objects. i had to select them all and re-scale via the maxscript, then use maxscript to collapse the stack. Quote macroScript RndPlacement category:"DragAndDrop" toolTip:"" (thetrees = selection as array for o in $Dummy* do ( r = random 1 thetrees.count thetree = instance thetrees[r] thetree.transform = o.transform ) ) Link to comment Share on other sites More sharing options...
