raymondlee1 Posted February 19, 2019 Share Posted February 19, 2019 I've been having some problems with my specular and refraction in Vray, Can anyone tell me what might be causing this issue. reflections seem to create this strange bubble within the model and doesn't look true to life. only have hdri environment and a floor. any help is appreciated. Thanks Link to comment Share on other sites More sharing options...
eduardasvuskvariokas Posted February 20, 2019 Share Posted February 20, 2019 Might be good idea to double check your model. There might be flipped polygons (thinking of this since it seems you used lathe and at least for me that was a rather common problem untill I got into habbit of always checking them after latheing). If polygons are ok then no idea. Try recreating the form again, doesnt look like complicated one. Link to comment Share on other sites More sharing options...
raymondlee1 Posted February 20, 2019 Author Share Posted February 20, 2019 Hmm not sure about the normals as they all seem to be pointing the same right way, however when I render refractive materials it looks even worse. Don’t see what I’m doing wrong here must be some setting that I must have checked somewhere Link to comment Share on other sites More sharing options...
