Pixelated renders
veraoleo
Hi, I have a problem, my renders are fine, but when I am increasing the size they are becoming pixelated. When I render only a small part at once of the whole image they are great. I have been incrising all the values, but it doesn't work. What should I do?
Please refer to the help doc of V-Ray, the settings that you are displaying are not related to the 'issue' you are asking.
V-Ray is a very complex render engine, but if you understand the basics, it becomes easier to use.
The first images show a none finished rendering or one that has not enough samples.
By default V-Ray will render for only one minute, this in progressive mode, depending on how complex your scene is and how large your image is, that 1 minute won't be enough to clean up your image.
  • 2 weeks later...
Do you mean to say if you are rendering region with the same settings the render is coming up great?
and with the same setting, the whole render is pixelating?
Better if you share the complete settings - and I would recommend to reset Vray settings and keep it on "Bucket" rather than "Progressive".
