samazc Posted March 23, 2019 Share Posted March 23, 2019 Hello! I’m a frequent user of VRay for 3ds max but for the first time vray camera white balance produces render with blue hue for an interior shot (with four windows) even though it is set on Neutral? The only way that seems to fix it is to set it on D65 to subtract the bluish effect but thats a set up for exterior shots! This a light balance excersice file, the solution file has the same exact setting im using but the render produces no blue hue with the white balance on Neutral.. I’m so confused here does anyone have a clue of what could possibly be the problem? Link to comment Share on other sites More sharing options...
John Dollus Posted March 25, 2019 Share Posted March 25, 2019 If you are using an HDRI file to add environment light through the windows, that could be the culprit. Check the solution file and make sure they are not compensating through the VFB controls. A fast way to do this would be to open the solution file, delete everything form the scene, merge in everything from your scene and see how it renders. Link to comment Share on other sites More sharing options...
