maxehrlich Posted May 2, 2019 Share Posted May 2, 2019 I have a job that calls for a 60K x 30K rendering. I used blowup to render a beauty pass in 9 sections. Now I want to render a pass with refractive materials and would like to use render region to selectively render portions of the viewport but I am limited by the 3dsmax limit of 32678 x 16384. How are others working around the limits of 3dsmax's render size? Link to comment Share on other sites More sharing options...
akshayarora Posted May 8, 2019 Share Posted May 8, 2019 It's a huge requirement - sorry I have no idea how to increase that. May I know why you need such a huge size, just curious to know - I have one more question in mind, why 3Ds max is restricted to this size ( 32678 x 16384 ) specifically? Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted May 8, 2019 Share Posted May 8, 2019 This is for a billboard? If so keep in mind that the image will be viewed from a distance, so there is no real need for it to be super detailed. However, here are some links you may want to check out: https://forums.chaosgroup.com/forum/v-ray-for-3ds-max-forums/v-ray-for-3ds-max-general/22361-large-render-size-question https://docs.chaosgroup.com/display/VRAY3MAX/Rendering+Very+Large+Images https://forums.autodesk.com/t5/3ds-max-forum/how-can-i-render-larger-than-the-max-limitations/td-p/4081524 https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/sfdcarticles/sfdcarticles/Rendering-Very-Large-Images.html Good luck! Link to comment Share on other sites More sharing options...
jesusgomez2 Posted May 8, 2019 Share Posted May 8, 2019 That requirement has no sense at all. For any wall advertisement or whatever you don't need that resolution, actually could be a problem for printers to manage those huge files. Anyway, render by parts it's what i would do... Link to comment Share on other sites More sharing options...
Lewis Garrison Posted May 8, 2019 Share Posted May 8, 2019 Yeah rendering that big means they didn't take into consideration viewing distance. I'd check their requirements before figuring this out. Link to comment Share on other sites More sharing options...
