adityasurlakar Posted May 10, 2019 Share Posted May 10, 2019 Hi I have grown a ivy on pole. And I want to get the GrowFX animation into Modo. In max i have assigned multi/sub-Object to Grow fx (attached image of same). I tried exporting animation in alembic format and also as vray proxy but the materials are not coming properly in modo. (preview from Modo) These are all the steps i tried: 1) Exported single frame as alembic from max to modo and shaders workes properly. 2) Exported animated vrscene from max to modo but in this case the grow fx doesnt load at all in modo only the pole mesh can be seen. 3) Exported animated alembic from max, opened the alembic file in modo but non of the part tags are coming for Grow fx. 4) Tried loading alembic as a Vray proxy in modo, this time the Grow fx part tags are displayed but the Materials are messed up as can be seen in the image. I also tried rendering few frames from the animated sequence and the material flickers for each frames. Attached images of same (Animated preview from Modo). Can anyone help me with this issue? Thank you Link to comment Share on other sites More sharing options...
