anvaraziz Posted December 22, 2004 Share Posted December 22, 2004 hai all.. i got some 3ds files of plants tress n shubs ( from dosch garden designer) the maps are all in same folder where 3ds files are. but when i render , alpha maps r missing from leafs n flowers ,,, how can i fix it... pls help........ Link to comment Share on other sites More sharing options...
Bhanu Posted December 22, 2004 Share Posted December 22, 2004 Some times it needs to mannually configure the bitmap path of 3ds file. Check the name of bitmap applied in material editior and try to configure the bitmap locations. Link to comment Share on other sites More sharing options...
kippu Posted December 22, 2004 Share Posted December 22, 2004 customize paths ------- add that folder to the maps area that should work fine Link to comment Share on other sites More sharing options...
STRAT Posted December 22, 2004 Share Posted December 22, 2004 also, the 3ds files may not be 100% 'ready-to-go' with your version of max/viz, and my need the materials tweeking slightly. what does the material in the mat editor look like? Link to comment Share on other sites More sharing options...
anvaraziz Posted December 22, 2004 Author Share Posted December 22, 2004 also, the 3ds files may not be 100% 'ready-to-go' with your version of max/viz, and my need the materials tweeking slightly. what does the material in the mat editor look like? material editor is empty,, so i cant tune it using material editor, yes kippu, ill try like what u say,, Link to comment Share on other sites More sharing options...
