SajSingh Posted September 13, 2019 Share Posted September 13, 2019 Hello, Does anyone know how to map a floor surface which is not uniform, for example a large graphic carpet to fit a map perfectly to the model shape. I have a floor design which has a border that goes all the way around. Thanks, Link to comment Share on other sites More sharing options...
TomD_Arch Posted September 16, 2019 Share Posted September 16, 2019 Yes. Link to comment Share on other sites More sharing options...
SajSingh Posted September 16, 2019 Author Share Posted September 16, 2019 Any chance you could show me the best way to achieve this please? Link to comment Share on other sites More sharing options...
TomD_Arch Posted September 17, 2019 Share Posted September 17, 2019 No. You haven't provided any of the requisite information someone would need to start helping you. Link to comment Share on other sites More sharing options...
SajSingh Posted September 19, 2019 Author Share Posted September 19, 2019 I'm sorry, new here, I don't know what you mean by required information... Please let me know what you need. Thanks, Link to comment Share on other sites More sharing options...
TomD_Arch Posted September 19, 2019 Share Posted September 19, 2019 What program and version are you using, what rendering software, etc. Maybe post an image of the rug map you are using so others that want to help can use it to post an example back, etc. Link to comment Share on other sites More sharing options...
SajSingh Posted September 19, 2019 Author Share Posted September 19, 2019 Sure, I'm using 3D MAX with Corona render. The job is commissioned so unfortunately I'm not allowed to share the file. But I'm guessing this would be a generic solution to flooring.? Link to comment Share on other sites More sharing options...
John Dollus Posted September 19, 2019 Share Posted September 19, 2019 well, if I understand you correctly, you are trying to create an inset within a floor shape that contains more than 4 corners but that's just a guess. One way would be to select your floor object, edit poly, select the floor surface and then inset it by whatever dimension is your border and either detach it as a separate object or assign a unique mat ID and handle it through the material definition. That's about as generic as i can give ya without more info. Since everything is top secret, how about finding a similar image on Houzz and uploading that instead? Link to comment Share on other sites More sharing options...
SajSingh Posted September 19, 2019 Author Share Posted September 19, 2019 Ok sure. I'll create a file. Thanks for your help!! Link to comment Share on other sites More sharing options...
