jonathan Evans Posted September 16, 2019 Share Posted September 16, 2019 The vray frame buffer is showing colour of the standard vray material grey with yellow tint . When save the file as jpg to my desktop correct grey is produced on the image Link to comment Share on other sites More sharing options...
James Vella Posted September 17, 2019 Share Posted September 17, 2019 (edited) make sure in vray you enable the gamma curve in the VFB, this button here. The image on the right is how it should be viewed. Otherwise if your intention is the image on the left ensure you save your images with gamma disabled if saving straight to jpg (or in photoshop put a exposure adjustment and set the gamma to 0.45). If you are doing anything photorealistic then I suggest you learn to work with the gamma curve enabled, you can read more about this below: https://www.cambridgeincolour.com/tutorials/gamma-correction.htm additional FYI: In general you should be working with the gamma curve enabled regardless unless you have a specific reason not to (such as linear compositing, non destructive workflow baking in the gamma etc) but otherwise save yourself the headaches and turn it on. Edited September 17, 2019 by redvella Link to comment Share on other sites More sharing options...
jonathan Evans Posted September 17, 2019 Author Share Posted September 17, 2019 i want the image on the right to be what view in the frame buffer. I am happy with image on the right . i want this image to be avaiable inth e frame buffer Link to comment Share on other sites More sharing options...
James Vella Posted September 17, 2019 Share Posted September 17, 2019 have you enabled the button in the VFB from the screenshot I provided, did it still produce the same result? Link to comment Share on other sites More sharing options...
jonathan Evans Posted September 17, 2019 Author Share Posted September 17, 2019 i dont have the same button layout avaiable on vray frame buffer Link to comment Share on other sites More sharing options...
James Vella Posted September 17, 2019 Share Posted September 17, 2019 press the sRGB button. Link to comment Share on other sites More sharing options...
jonathan Evans Posted September 17, 2019 Author Share Posted September 17, 2019 sorted thanks you rught the srgb button wrks Link to comment Share on other sites More sharing options...
James Vella Posted September 17, 2019 Share Posted September 17, 2019 Great to hear, good luck! Link to comment Share on other sites More sharing options...
