Drawing straight walls...
cullen
I'm sure that this is something that is going to be something simple. I'm wondering if anyone knows how to make the wall object draw at 90 degree angles. (how a line does when you hold down shift) I can't find an ortho command in max. I know there was one in VIZ. Oh and I'm using MAX 6.
Thanks for the help.
crw
crw
Not a direct answer nor an elegant way to do it -
but you could also draw the spline path first (which allows easy 90 degree
turns) and create a wall using the keyboard entry (where you just pick the
spline and walls are automatically created)
vertex
