gabrieldomingues1 Posted January 25, 2020 Share Posted January 25, 2020 Hello everyone, I saw some interesting pictures that I want to recreate on max so I can render some shots, the only struggle I have is finding the dimensions of my reference inge, things like the height of a window the width of a shelve etc. Is there any way to know them or is it by eye? Thanks Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted January 26, 2020 Share Posted January 26, 2020 usually if you don't have any dimensions, you need to look for some element in your image that you know the correct size. the model of a TV, or Table, chairs or something like that. Then after matching your camera, scale your image until it fit correctly your object, everything else will be a relative proportion of that object. If you know any dimension then an educate guess can do the job too. There are standard sizes for doors and windows, and you can test with that. for instance here in USA a standard residential door is about 6'8" so matching the photo to fit that dimension will do the trick. best luck. Link to comment Share on other sites More sharing options...
Beat Color Posted June 19, 2020 Share Posted June 19, 2020 We do virtual staging and we usually base on the doorknobs, the height of the house, windows,.. then scale the ratio of furniture Here are some work Link to comment Share on other sites More sharing options...
Mamoon Bestani Posted July 6, 2020 Share Posted July 6, 2020 you can improve your knowledge, by reading more topics about interior design, also you can search an example on " standard kitchen cabinet sizes" or any size you need. by this way your sense to the sizes and object scales will improved . Link to comment Share on other sites More sharing options...
