Jimmy Compton Posted January 26, 2020 Share Posted January 26, 2020 Is there any way to get a more intense bokeh effect in my renders? It seems no matter how much I increase the dof, I never seem to get any of those 'crisp' sort of bokeh spots. Thanks in advance for any help. Link to comment Share on other sites More sharing options...
kemalettinozkan Posted February 26, 2020 Share Posted February 26, 2020 Maybe You can experiment with Aperture and Focal Length. Good luck with.. Link to comment Share on other sites More sharing options...
Jimmy Compton Posted February 27, 2020 Author Share Posted February 27, 2020 Maybe You can experiment with Aperture and Focal Length. Good luck with.. I'll look into it. Thanks. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted February 27, 2020 Share Posted February 27, 2020 Boke is the effect of many settings is not just, give more boke button. You need to have a good combination of Fstop, lens size number of blades in your lens and light sources. Usually for a stronger boke effect you need, small light with high intensity, a more polygonal-shaped your lens blades, also a small FTop number, 2 or less, a larger lens size such 50 or more. THen setup your scene so there is a clear distance and differentiation between your focus object and the background. Link to comment Share on other sites More sharing options...
