markandrue Posted February 21, 2020 Share Posted February 21, 2020 Step 1: Click on Download links. Step 2 : Click on Revit Products Step 3 : Click on Revit Step 4 : Download the three Parts under the Revit 2018 64bit option. Once they have downloaded the content I tried the installation myself. I switched off the UAC (User Account Control). To do this you access the Windows Control Panel and User Accounts. I also disabled the Antivirus protection, setting it to enable upon restarting the PC. Link to comment Share on other sites More sharing options...
Silicon Valley infomedia Pvt. Ltd. Posted August 1, 2024 Share Posted August 1, 2024 To download Revit properly, follow these steps: Check System Requirements: Ensure your computer meets the minimum system requirements for running Revit. You can find the system requirements on the Autodesk website. Create an Autodesk Account: If you don’t already have one, go to the Autodesk website and create an account. This is necessary for downloading and activating Revit. Sign In: Log in to your Autodesk account. Download Revit: Navigate to the Revit product page on the Autodesk website. Select the version of Revit you want to download. Click on the "Download" button. Choose Download Method: Autodesk typically offers two download methods: "Install Now" and "Download Now". "Install Now" allows you to download and install the software in one step. "Download Now" lets you download the installer first and then install the software offline. Run the Installer: Once the installer is downloaded, open it to begin the installation process. Follow the on-screen instructions. You may need to accept the license agreement and choose the installation location. Select Components: During the installation, you might be prompted to choose which components to install. Select the ones you need and proceed. Install Revit: Click "Install" to start the installation. This process may take some time depending on your system and internet speed. Activate Revit: After installation, launch Revit. You’ll be prompted to activate the software. Use your Autodesk account credentials to complete the activation. Update Revit: After installation, check for any updates or service packs available for Revit and install them to ensure you have the latest features and bug fixes. Following these steps should help you download and install Revit properly. If you encounter any issues, refer to the Autodesk support resources for additional help. Link to comment Share on other sites More sharing options...
Silicon Engineering Consultants Pty Ltd Posted August 21, 2024 Share Posted August 21, 2024 For Silicon Engineering Consultants Pty Ltd, follow these steps to download and install Revit: System Check: Ensure your system meets Revit's minimum requirements by checking Autodesk’s official website. Create/Log in to Autodesk Account: Access the download by logging into your Autodesk account or creating one if you haven't already. Download Revit: Go to the Autodesk site, select Revit, and choose the correct version and language. Click "Download" and select the appropriate license type for Silicon Engineering Consultants Pty Ltd. Installation: Run the installer, follow the prompts, and configure settings as needed. Ensure all necessary plugins are selected. Activate: Launch Revit post-installation, sign in with your Autodesk account, and activate the software using the company license. Update: Check for and install any available updates to keep the software current. Link to comment Share on other sites More sharing options...
