How can we help promote each other
Sketchrender
I was just thinking we should set out exactly the areas we work in so if somebody comes across work they don't do we can send it on to the person that does. For example I don't use VRay (probably because I'm too tight to pay for it).
As well as Architectural, I do a lot of engineering such as roads & rail. I tend to do mostly animations these
days as I find people are requesting them more then stills and I also do interactive animations. I have also used add-ons such as Fume FX
I use 3DS Max, Revit, AutoCAD Architect, AutoCAD & MicroStation. I also teach all of these.
Good idea.
I work in the architectural field.
Stills mostly, working on animations again recently.
I am working with Engineers mostly at the present, as thats were the work is, Large Masterplans ect.
Quick turn around generally.
Software: Max 2012, Vray 2.0, Multiscatter, Adobe CS 5.5 Standard, all the usual Autodesk suite for work.
Based in Dublin Fumbally Exchange.
