Problem MultiTexture Maps
omar taha
In the multitexture map there are some boxes you can check for different functions. You may set it to use face ID or perhaps make it work with bercontiles. If you set it to the wrong one you may get bad results. If you use face id, make sure your geometry has different IDs (you may try the material by element modifier if you have lets say a floor with separate floortiles (different elements within an object).
  • Thanks 1
Expand
Really Thank you for helping I was trying that and it's work with multitexture but don't show in viewport with vray materials for that i have to modify the texture scale in the polygons during reading but it's work well with standard materials in max
