Jimmy Compton Posted September 9, 2020 Share Posted September 9, 2020 Is it possible to make a vertex selection using a texture map like you can in the Cloth > Make Group modifier? (Max 2019.) I've tried copying a selection out from the Cloth modifier, but it doesn't seem like you can. Thanks in advance for any help. Link to comment Share on other sites More sharing options...
Changsoo Eun Posted September 13, 2020 Share Posted September 13, 2020 Use Data Channel modifier to copy vertex selection as UV or vertex color. Then, use vertex color map or gradient. Link to comment Share on other sites More sharing options...
Josef Wienerroither Posted September 14, 2020 Share Posted September 14, 2020 or use the old Volume select modifier.. has a texture option too... 1 Link to comment Share on other sites More sharing options...
Jimmy Compton Posted September 14, 2020 Author Share Posted September 14, 2020 It was the texture select option in the Volume Select modifier I was looking for. I feel like it should be named Surface Selection or something else, not Volume Select. To me, that's not a volume. I basically got lucky finding it under Volume Select. Thanks. Link to comment Share on other sites More sharing options...
