Kacper Pach Posted January 23, 2021 Share Posted January 23, 2021 How would you go about having a 1:100 scale scene in 3ds max but working with a bunch of import files in 1:1? I've been trying to use depth of field using v-ray camera in 3ds Max. Because the depth of field can only work on relatively small objects I ended by rescaling my site model file by 0.01. So from now on, I planned to do all my Max files in this 1:100 scale. But it causes problems. For example, Forest pack defaults don't work ideally in such a small scale as well as importing some 1:1 scale asset. My system units are 1=1m (and display units happens to be in millimetres). My workflow is: xref-ing my model files that contain geometries into a render file that contains cameras, lights and render settings and using one render files to render various design options. Link to comment Share on other sites More sharing options...
Chris MacDonald Posted February 9, 2021 Share Posted February 9, 2021 You're going to have to use very unrealistic F-stop values is all. Usually you might work in the range of f1.4 - f11, but you for the purposes of making a 1:1 model feel like a scale model you'll need to go down to f0.1 etc. Of course, this will mean you'll need to use a super fast shutter speed/very low ISO to compensate for the gain in exposure value. Link to comment Share on other sites More sharing options...
