Johan Reyns Posted April 20, 2021 Share Posted April 20, 2021 Hello I've a problem using forest pro, I'm trying to get a hedge on a surface with uv but only the beginning and the end of the volume are attached see file anyone 've an idea ? Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted April 26, 2021 Share Posted April 26, 2021 Not really sure, but a guess would be that you have used a planar uv map before applying forest pack? For some pointers to the way you are trying to create hedges, you may want to check out this tutorial from itoosoft, they even have an example you could download and compare to your own project: https://www.itoosoft.com/tutorials/creating-trimmed-hedges-and-topiary Link to comment Share on other sites More sharing options...
Johan Reyns Posted April 26, 2021 Author Share Posted April 26, 2021 Hello Nicolai, I found the problem, the problem wat the uv mapping, when I did an uv mapping is was solved, thx for your reply Link to comment Share on other sites More sharing options...
