creating custome wall styles
Josh1587140445
  • 2 weeks later...
Basically:
format dropdown menu> style manager> Architectural objects> pick wall styles> right click in right window and select 'new'
rre-name new and then rightclick & choose edit> right click in main window will allow you to add more components to you wall. Then there are several options such as width etc you can amend.
Hope this helps. Im no expert on this but had to create a couple of wall styles that related to UK house construction.
Or you could copy and rename a similar wall type and edit that same process )almost as above)
Regards,
Al.
