Roland Nakhoul Posted August 16, 2022 Share Posted August 16, 2022 Its a little hard to explain what i mean, but i want to move each vertex on Z axis continuously and by the same distance interval, ex: first vertex 20cm, second vertex 40cm, 3rd 60cm... untill the last vertex in spline. Is there any known script or can someone help me with a script because i dont know how to code thank you all Link to comment Share on other sites More sharing options...
Tom Bussey Posted August 17, 2022 Share Posted August 17, 2022 assuming 3dsMax: can you not just make a spline of known length, and divide by known number (Divide in editable spline)? Link to comment Share on other sites More sharing options...
Scott Schroeder Posted August 17, 2022 Share Posted August 17, 2022 (edited) Do you need something like this? https://www.itoosoft.com/freeplugins/splineoffset There may also be something on ScriptSpot for you as well. http://www.scriptspot.com/ EDIT: I just re-read the request and spline offset may not be what you are asking for. The other way to do what I think you are asking is just create a plane that is the slope that you want, and use the Glue modified to glue the spline down to that plane. https://www.itoosoft.com/freeplugins/glue Edited August 17, 2022 by Scott Schroeder Link to comment Share on other sites More sharing options...
