Judson Rogers Posted August 26, 2022 Share Posted August 26, 2022 Using Max 2023 and Vray 6.2...I had render elements (specifically, lightmix) working just fine upon initial install. I must have clicked an option by mistake (knowing max, there are probably five check boxes to enable/disable render elements) and now, during and post rendering, render elements is not available in VFB. Gotta get lightmix back. Any guidance or suggestion would be most appreciated. Link to comment Share on other sites More sharing options...
Tom Bussey Posted August 31, 2022 Share Posted August 31, 2022 Maybe the easiest thing would be to save your render settings all except elements, rest by switching to arnold and back to Vray, then re-load your settings and add the lightmix element back in, it should then have the elements tab in the default state + your lightmix element. Link to comment Share on other sites More sharing options...
Tom Bussey Posted August 31, 2022 Share Posted August 31, 2022 just saw this was posted on Friday... so a tad late! Link to comment Share on other sites More sharing options...
