jujubeleza Posted January 6, 2005 Share Posted January 6, 2005 Hi, I´m new for v-ray and i´m using free 1.09. The UVW map isn´t working in render image. What I need to do to use the UVW map with v-ray? Link to comment Share on other sites More sharing options...
kippu Posted January 7, 2005 Share Posted January 7, 2005 is there a image that you can show us .... because it works fine for me .... except that you have to decrease the BLUR in the map parameters from the default 1 to 0.1 or change the filtering from PYRAMIDAL to none .... hope that helps Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted January 7, 2005 Share Posted January 7, 2005 it shouldn't be any different than without usng vray. Link to comment Share on other sites More sharing options...
David Knourek Posted January 7, 2005 Share Posted January 7, 2005 crazy homeless guy said: it shouldn't be any different than without usng vray. Yea I hav'nt had any troubles like that with V-Ray, and Ive been using it since it forst went public... -dave Link to comment Share on other sites More sharing options...
rivoli Posted January 7, 2005 Share Posted January 7, 2005 as long as i know uvw work in vray as they work in max. you should check how your scene render with the scanline, maybe it's a max setup problem. Link to comment Share on other sites More sharing options...
