Khaled Awad Posted December 27, 2023 Share Posted December 27, 2023 1.tifI don't understand what's wrong and why on the left of the picture there's some weird black smudges on the wall? sorry for the quality I'am still a beginner 😄 Link to comment Share on other sites More sharing options...
James Vella Posted January 1, 2024 Share Posted January 1, 2024 Are you using denoiser in the render settings? If so turn it off and see if it still appears the same. If it doesnt then your render time is too short and not enough samples in the darker areas of the images are creating a smudged appearence - render longer and do a test region on that spot. Link to comment Share on other sites More sharing options...
Khaled Awad Posted January 1, 2024 Author Share Posted January 1, 2024 10 hours ago, James Vella said: Are you using denoiser in the render settings? If so turn it off and see if it still appears the same. If it doesnt then your render time is too short and not enough samples in the darker areas of the images are creating a smudged appearence - render longer and do a test region on that spot. this render took 6 hours 50 minutes. I tried different files but it happens in this one only Link to comment Share on other sites More sharing options...
