bully712 Posted January 10, 2005 Share Posted January 10, 2005 I have a drawing that when I am in the top view, the 0,0 insertion point is in the correct location. I then use an isometric view to create 3D walls. When I switch back to the top view, the 0,0 insertion point jumps down the screen. I have attached the file below. Out of 4 levels, this is the only floor that I'm having a problem with. Any help will be appreciated.. Thanks, Link to comment Share on other sites More sharing options...
mtutaj Posted January 10, 2005 Share Posted January 10, 2005 I would check to see if your ucs is in world mode and that your base point is set to 0,0,0.. those are the first 2 things I would look at. Mike Link to comment Share on other sites More sharing options...
