Kals Posted September 3, 2003 Share Posted September 3, 2003 Hello Guys I am researching on the theory of radiosity. The way radiosity works and how it calculates and works in softwares like 3ds max 5. Can anyone suggest me the best place to start out with knowing the fundamentals till all the theory of radiosity. Thanks Kalyan Link to comment Share on other sites More sharing options...
choochee Posted September 4, 2003 Share Posted September 4, 2003 Try looking at the beginners... LIGHTSCAPE by autodesk. This is the first radiosity renderer I know and maybe they will give you some explanation about their solution. Link to comment Share on other sites More sharing options...
John Dollus Posted September 4, 2003 Share Posted September 4, 2003 'Rendering with Radiance' by Greg Larson and Rob Shakespeare ia an excellent book that goes through many different methods in detail. I highly recommend it from a research point of view. JD Link to comment Share on other sites More sharing options...
nuno Posted September 4, 2003 Share Posted September 4, 2003 do a search on MIT there are lots of info in there Link to comment Share on other sites More sharing options...
Craig Ramsay Posted September 5, 2003 Share Posted September 5, 2003 Check out the Global illumination and radiosity articles in the resources section of this site! Craig Link to comment Share on other sites More sharing options...
jackb602 Posted September 5, 2003 Share Posted September 5, 2003 Here are some links I've found very helpful in learning about the theory behind various methods for calculating Global Illumination. The clearest explanation of the Radiosity method I've found: http://freespace.virgin.net/hugo.elias/radiosity/radiosity.htm Global Illumination Compendium http://www.cs.kuleuven.ac.be/~phil/GI/ Henrik Wann Jensen developed Photon Mapping, the GI system used in Cinema 4D, Brazil, and others. This is his home page: http://graphics.ucsd.edu/~henrik/ Hope this helps, Jack Link to comment Share on other sites More sharing options...
