Sawyer Posted August 6, 2003 Share Posted August 6, 2003 I am wondering if there is a program that lists the contents of any folder so you can print it (as opposed to alt+printscreen) Thanks all [ August 06, 2003, 11:36 AM: Message edited by: Sawyer ] Link to comment Share on other sites More sharing options...
kainoa Posted August 6, 2003 Share Posted August 6, 2003 ACDSee has a function for that. I'm using version 5 so I'm not sure if older versions have it too. Just hit CTRL+G, and presto...it writes all the contents into a text file. You can also filter your file listing to list only images, folders, etc. ACDSee Info Link to comment Share on other sites More sharing options...
Diego Rosales Posted August 6, 2003 Share Posted August 6, 2003 Thanks Kainoa. I've been looking for something like this for ages and I didn't even know ACDSee had this feature built in. Nice tip!. Link to comment Share on other sites More sharing options...
Sawyer Posted August 6, 2003 Author Share Posted August 6, 2003 Thanks - that was not quite what I wanted but I think it may work - at least gives me something to go off. Link to comment Share on other sites More sharing options...
kainoa Posted August 6, 2003 Share Posted August 6, 2003 No prob Diego. What exactly is it you were looking for Sawyer? Link to comment Share on other sites More sharing options...
Sawyer Posted August 6, 2003 Author Share Posted August 6, 2003 Ok here it is - We work on a slew of cad details hundreds per project and I want to make sure they are getting filed right (we have one detail folder with standard details and then we have project specific detail folders). I want to be able to just see what is in each folder but some times there are folders & subfolders so the details are scattered among 30 or so folders & that is a lot of searching. I was hoping I could find something that lists all folders/subfolders from a given point. Does that meke sence? Link to comment Share on other sites More sharing options...
kainoa Posted August 6, 2003 Share Posted August 6, 2003 Oh I see...you would like to list the entire tree of contents in a specified directory. Hmmm...sorry I dont know any apps off hand. Good luck to you! Link to comment Share on other sites More sharing options...
Diego Rosales Posted August 6, 2003 Share Posted August 6, 2003 Sawyer, There are some digital asset management tools that should do exactly what you looking for. I know about some, but most are expensive high-end apps. I believe this kind of software will do the trick. http://www.extensis.com/assetman/ http://www.canto.com/ http://www.nxn-software.com Of course, the cheapest is to do proper naming and deploy a logical folder structure making the most out of the UNC. If you have free time, take a look at this book ($2.76 used) about knowledge asset management. It gives a solid overall view of how asset management should work. /Diego Link to comment Share on other sites More sharing options...
Zoranm Posted August 12, 2003 Share Posted August 12, 2003 If you are a windows user go to command prompt, change to a directory you want to output and type: dir /s/b >mydir.txt This will give you a full list of files sorted by directories and all shell be wtitten to mydir.txt. For more options of dir command type: dir /? Memeories of good old DOS days!! Regards Zoran Link to comment Share on other sites More sharing options...
