johncdg Posted January 22, 2005 Share Posted January 22, 2005 I have an issue about net rendering. The rendering is not completeing because theres a missing map or missing mapping coordinates. Isn't there a switch that will require the rendering proccess to continue anyway, rather than causing the rendering procces to stop? I have looked through the Max help files with little luck. Link to comment Share on other sites More sharing options...
Bugga_Guy Posted January 22, 2005 Share Posted January 22, 2005 I have wondered that myself for a long time, but personally I do not think it possible. I just accept that a little extra time has to be put in assigning proper UV co-ordinates. As for Maps, why would spend all that time having to render something missing its textures? Link to comment Share on other sites More sharing options...
tuekappel Posted January 22, 2005 Share Posted January 22, 2005 personally, i would use the ressource collector together with the file>Archive>map/photometric path editor to gather and check my bitmaps. Also you can check "include maps" in your network job assignment dialog box. this will create a lot of network traffic, though, so use that option with caution. But regarding the UVW coordinates, i hear ya. that's so-o-o-o annoying... Link to comment Share on other sites More sharing options...
