rayray Posted January 23, 2005 Share Posted January 23, 2005 I’m trying to trace over a car from a bitmap. Unfortunately, I lose a lot of quality once the bitmap is assigned to a plane. The lines in the image are converted into big pixels. I tried importing the images with a higher resolution but that didn’t work either Is there a way I can keep the quality once it is assigned to a plane? Link to comment Share on other sites More sharing options...
Bugga_Guy Posted January 23, 2005 Share Posted January 23, 2005 It all depends on how good your video card is... Go to "Customize", "Preferences" then "Viewports" Click the Configure Driver button under "Display Drivers". Now depending on what kind of video card you have is where quality comes into play. Set Textures to "1024" and make sure the "match bitmap as close as possible" is checked. That should do it. Link to comment Share on other sites More sharing options...
rayray Posted January 23, 2005 Author Share Posted January 23, 2005 Wooooww.....what a differents. All lines are now visible. Only thing is that i don't have the 1024 option. It goes up to 512. Well, at least i got the details back. Thanks man Link to comment Share on other sites More sharing options...
