Arnel Posted January 25, 2005 Share Posted January 25, 2005 This is posted by Adegnan at AUGI and share it here as this might interest the others. Quote: Originally Posted by Kevin Roche [Kevin.Roche@winest.com ] Currently we use CAD translation tables to connect with Revit. This involves a one time set-up in which you map Revit objects with WinEstimator line item database. Once you have done this it means a file created in Revit can be brought in to WinEstimator resulting in instant take-off quantification of costs! Basically it is an instant cost estimate based on a Revit file. The one time set-up is rather easy and we can do it for you if you do not have time. The following link leads to a quick demo showing the how the process works: http://www.winest.com/repnet/varflash/Revit.html Taking it a step further later this year we will have direct integration with Revit via its API. This means as you build a file in Revit it is automatically compiling a cost estimate in WinEstimator (which is running in the back ground), meaning zero set up time. We are in the early stages of development on the API, I can show it to you as soon as more information is available. Please use me as a resource for any questions you may have. Link to comment Share on other sites More sharing options...
NEVIANS Cedric Architect Posted January 25, 2005 Share Posted January 25, 2005 hello big interest in this API Winest integration .... very powerfull do you think that european version birth ? (french german ??) thanks for reponse Link to comment Share on other sites More sharing options...
Arnel Posted January 25, 2005 Author Share Posted January 25, 2005 Nevian you can go directly to their website and post your question their. here is the link http://www.winest.com Link to comment Share on other sites More sharing options...
Richard McCarthy Posted January 28, 2005 Share Posted January 28, 2005 Cool find Arnel Link to comment Share on other sites More sharing options...
