Danny Posted January 25, 2005 Share Posted January 25, 2005 This my latest project in Malaysia 3 storey Bungalow and 8 Storey Condominium, still i prelimenary stage, C & c are welcome specialy on the rendering. This project render by lightwave and photoshop. thank you. Link to comment Share on other sites More sharing options...
IC Posted January 25, 2005 Share Posted January 25, 2005 That looks like a huge amount of modelling there but we don't get to appreciate it. Instead, all I see are identical trees and badly repeating road texture. Do you have to keep the aerial camera view? If so, a bit of work is required on the above. Also, the fog is slightly odd. Link to comment Share on other sites More sharing options...
lambros Posted January 25, 2005 Share Posted January 25, 2005 Trees may not pose a special problem, but the road tiling looks unprofessional. Also, the whole render seems flat and dull, you should try to cheer up the lighting, perhaps use some radiosity, or give it some contrast. The modelling looks good though! Try to make good use of it Link to comment Share on other sites More sharing options...
ipdesigner Posted January 25, 2005 Share Posted January 25, 2005 *if you could lower your camera angle, maybe 20-30MTS above ground level could be better....just my idea i want to achieve and appreciate the elevation-design of ech unit. not like here, more than 50% of the view of the houses show the roof..and it is a repeating design.. *btw, its good for presentation...congratulations! Link to comment Share on other sites More sharing options...
Danny Posted January 27, 2005 Author Share Posted January 27, 2005 Thank you for all the comment i will post the finish product when it done. Actually the camera veiw its wierd because in order to comply with local authority requiment, any where i will bring the camera a bit lower, and improve on lighting and texture mapping. normaly how all of you textured the road?. thanks. Link to comment Share on other sites More sharing options...
IC Posted January 27, 2005 Share Posted January 27, 2005 http://www.cgarchitect.com/vb/showthread.php?t=8495 Link to comment Share on other sites More sharing options...
