error .. pls help
anvaraziz
when i opend one of previous dwg file i got this message
i tried to recover the file but ...
then its giving "error 53 (eFilerError) object discarded"
then when i cancel autocad is closing suddenly..
any other way to recover that file.....
pls help guys///////////////
If the drawing that you're trying to open doesn't have any AEC objects you can use Autodesk migration tools and convert the drawing to at 2000 format without having to use AutoCAD. When you finish that, open the drawing through recovery. If you don't have the migration tools installed, you should be able to find them on your 2004 cd or through the Autodesk support center.
Have you searched Autodesk's support center for that error? Sometimes it tells an exact fix for a common error.
Hope that helps....
