architectural site Image
vizwhiz
ok
now That This has been Turned in about 45 minutes ago
how can i improve This arch Image (for The Next Time) ??
Thanks in advance
all constructive comments suggestions and etc will be greatly appreciated
now That the deadline is passed i finally have some Time to do a radiosity solution and will let This render overnite
CAD = change again daily
CAD = change again dammit
CAD = confused architectural drafter
CAD = confused architectural designer
CAD = cant add dimensions
Thanks
Randy
i am posting this relating to 3dmax, so it is a similar question to what might be in viz...
are you using max/viz built in logarithmic exposure control to adjust your images?
the reason i ask is that i was having similar results when i had it turned on in max, most notably with vray. the car and the trees in the lower left hand corner. the whites/grays are a purplish hue, and the overall balance seems out of whack.
It depends on your lighting source. How have you lit your scene?
I ran into a similar problem a while back in VIZ. If you are using just standard lights, try switching to an automatic exposure control as apposed to logarithmic.
again, change it again, daily
Thanks for the comments, greatly appreciated
i did a radiosity solution late yesterday afternoon
ran a render overnite, the computer ran out of memory
(supposed to have 3 gbs dont understand This)
re-did radio-solution rendered = worst Image splotches etc
so now later in The day i just found out That There are
Too many People, had to erase 3 of the 4 babes o no
added some exterior Tables with chairs and Umbrellas
ok, working on the sidewalk(s) concrete flat surfaces
presently using Logarythmic Exposure Control, 90000
computer is currently rendering at 100%
i will have to get back to check the settings
will update the Image sometime sooner or later
Randy
In reguards to your memory error, windows has issues using over 3 gig of memory in a single application, or something to that effect. Same problem happened to us.
To remedy this (provided your using xp) is to open your boot.ini and copy the line
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect
and change it to
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect /3GB
You might want to do a little research before playing around with this but this will more then likely fix your memory problem.
Randy,
Ram or virtual, memory? have had both errors, Makes a difference to solutions, quite often.
Log Exp control at 90,000 can BLOW the crap out of image maps, and extremes of value in colors. In viz/max it actually tends to double the 'flat' effect that so many complain about with the scan line renderer. Behaves like 'Curves" in PS, a little bit goes along way but it does not "fix" larger problems.
Can you get the illumination closer to "proper" levels without using any log Exp control? Then use Log Exp to psuedo adjust the 'exposure' like in photography:)
WDA
