Greg Hess Posted March 5, 2004 Share Posted March 5, 2004 While in windows, press ctrl-alt-del. Go to the performance tab. Do you see four processor threads running? If you don't, then hyperthreading isn't activated. Link to comment Share on other sites More sharing options...
David Knourek Posted March 5, 2004 Author Share Posted March 5, 2004 Just in case here are a couple examples. Xeon without HT: Xeon With HT: -dave Link to comment Share on other sites More sharing options...
kingeldar Posted March 5, 2004 Share Posted March 5, 2004 but u'll only see that if u choosed in processor history to have on graph per cpu otherwise u have only one graph despite u have 2 or 4 proc Link to comment Share on other sites More sharing options...
Greg Hess Posted March 5, 2004 Share Posted March 5, 2004 XP's default is per CPU I believe...but 2000's isn't. Link to comment Share on other sites More sharing options...
David Knourek Posted March 5, 2004 Author Share Posted March 5, 2004 Yes all 3 of my XP-Pro boxes default to the cpu split views. -dave Link to comment Share on other sites More sharing options...
kingeldar Posted March 5, 2004 Share Posted March 5, 2004 yes u r right default is per cpu i didn't notice that... sorry Link to comment Share on other sites More sharing options...
David Knourek Posted March 5, 2004 Author Share Posted March 5, 2004 Originally posted by kingeldar: yes u r right default is per cpu i didn't notice that... sorry No problem, I had forgotten about being able to reduce all the graphs into 1 Which Spline mite want to check out anyway if he did not set up his own workstation. Im so used to building and setting up new workstations myself that I often forget that there still is alot of people that still rely on others to build and configure their systems. Which as long as you do some carefull reading and follow the directions, "most" simple workstations or home systems can be built by the average user. Anyway Spline, what does your Task Manager say? -dave Link to comment Share on other sites More sharing options...
spline Posted March 5, 2004 Share Posted March 5, 2004 hi guys, i'm over crazy with this. here attach varius image to see my system spec. this is the info of my syste,i don't know if this xeon processor are 64 bits? i only see 2 graphics. see this: Nombre del sistema operativo Microsoft Windows XP Professional Versión 5.1.2600 Service Pack 1 Compilación 2600 Fabricante del sistema operativo Microsoft Corporation Nombre del sistema ARK1_SPLINE Fabricante del sistema Intel Technologies, Inc. Modelo del sistema Canterwood+ICH5 Tipo de sistema Equipo basado en X86 Procesador x86 Family 15 Model 2 Stepping 5 GenuineIntel ~2405 MHz Procesador x86 Family 15 Model 2 Stepping 5 GenuineIntel ~2405 MHz BIOS Versión/Fecha Phoenix Technologies, LTD ASUS PC-DL ACPI BIOS Revision 1003, 09/10/2003 Versión de SMBIOS 2.3 Directorio de Windows C:\WINDOWS Directorio del sistema C:\WINDOWS\System32 Dispostivo de inicio \Device\HarddiskVolume1 thanks for all !! Link to comment Share on other sites More sharing options...
spline Posted March 5, 2004 Share Posted March 5, 2004 could be that my system is installed in mpe function altrought acpi ????? jejeje, i'm trying to install 3 monitors. Link to comment Share on other sites More sharing options...
David Knourek Posted March 5, 2004 Author Share Posted March 5, 2004 hmm mine shows up as: Processor x86 Family 15 Model 2 Stepping 9 GenuineIntel ~2790 MHz -dave Link to comment Share on other sites More sharing options...
Greg Hess Posted March 5, 2004 Share Posted March 5, 2004 It sounds like hyperthreading is still disabled. Are you saving and exiting from the bios? Is there more then one hyperthreading setting? Everything seems ok, at least at a glance. Your processors support HT, your board supports HT, your OS supports HT...but HT isn't being enabled. The HT enable is under the "BOOT" menu. Make sure when you exit to SAVE and Exit, and not just esc out. Btw...you do have two processors right? (Just making sure, cause otherwise if HT was enabled, you'd just see two proc's and not four) Link to comment Share on other sites More sharing options...
David Knourek Posted March 5, 2004 Author Share Posted March 5, 2004 I'm not trying to be a smart ass but you do have two physcial processors rite Spline? -dave *EDIT* Nevermind Greg beat me to it Link to comment Share on other sites More sharing options...
spline Posted March 5, 2004 Share Posted March 5, 2004 dave, can be this ?? the only difference is the stepping, that i can't known can be mean. or could be that my system is mpe ? or are that my xeon's aren't 64 bits? Link to comment Share on other sites More sharing options...
David Knourek Posted March 5, 2004 Author Share Posted March 5, 2004 Your Xeon's are definately NOT 64bit. Is HT enabled in your BIOS as Greg mentioned? Xeons are currently only 32bit -dave Link to comment Share on other sites More sharing options...
Greg Hess Posted March 5, 2004 Share Posted March 5, 2004 Open the side of the case. Do you see two processors? Use Dave's photo as reference. Link to comment Share on other sites More sharing options...
spline Posted March 5, 2004 Share Posted March 5, 2004 ji,ji,ji. xDDD think that i inutil ? i've two processors. and yes, in my bios the HT is enabled. i think that when i installed windows, it ask me for choose mpe or acpi mode to continue installing. i choose mpe and i think that wrong choose. COULD BE THIS?,that make a power management and not enable the four process? i don't understand a lot of english but i think that david like my ass? isn't it? xDDDDDDDDDD Link to comment Share on other sites More sharing options...
David Knourek Posted March 5, 2004 Author Share Posted March 5, 2004 I'm not to sure what your getting at with the ass comment but there seems to be a serious breakdown in communication. Oh well, I noticed in your device manager that you have something by the big yellow "?" do you have the proper drivers installed for your mainboard/chipset? I only ask cause usually the device manager will have the processors listed in there and I dont see any listed as far as I can tell. -dave Link to comment Share on other sites More sharing options...
