calebabudu Posted February 7, 2005 Share Posted February 7, 2005 Hello everyone. this is my first posting on this site. i use revit, and a little bit of max. i'd like u look at these images and put any comments. thanks Link to comment Share on other sites More sharing options...
skippy Posted February 7, 2005 Share Posted February 7, 2005 quite good.... keep working.... 24 h in a day.... Link to comment Share on other sites More sharing options...
ecastillor Posted February 7, 2005 Share Posted February 7, 2005 Nice work overall for a beginner. Is the wall on the second image suppose to reflect? Next step is to give GI a try... Good luck Link to comment Share on other sites More sharing options...
Tim Nelson Posted February 7, 2005 Share Posted February 7, 2005 Is that rendered in Revit? Looks like Accurender without antialiasing. If you can smooth it out a little that would be a good first step. First image has a plant coming through the couch. You can find much better 3d furniture on various sites for free. Link to comment Share on other sites More sharing options...
Arnel Posted February 7, 2005 Share Posted February 7, 2005 Is that rendered in Revit? Looks like Accurender without antialiasing. If you can smooth it out a little that would be a good first step. Hi Tim the built in renderer for Revit is Accurender but you can also export it to viz/max to have greater control of materials ang lightings. From the look of the images It seems that he used the built in renderer of Revit. That's the only one thing I like Accurender it is very easy and simple to set-up that even first time user can produce descent images. Nice good start by the way. Link to comment Share on other sites More sharing options...
czoog Posted February 8, 2005 Share Posted February 8, 2005 Tim's right... the AA is bad. In revit, bump the resoultion of the image to 150 dpi for your output. I'd try running a radiosity solution on it as well, might come out cool. great start, but keep plugn' away! Link to comment Share on other sites More sharing options...
