Water Fountain - need the Water
vizwhiz
hello There
how do you do Water look-alike Spray in VIZ without the particle spray utilities
i already have 6 physical fountains, now i just need to add the Water
(its a dry heat down here in Arizona, just add water)
any comments greatly appreciated
I DO NOT HAVE MAX SO THEREFORE I CANT DO THE PARTICLE SPRAY SYSTEMS
maybe The Boss Man will have to buy MAX but until Then i got to do This
with what i already have and/or dont have
Thanks
Randy
Thanks Chad
no. They are not what i need, here is an Image of my doodle so far
i guess to be more specific That i already have the physical fountain modeled
(and rendered) so i need to make a mesh, probably 1 that falls over the edges
and 2 the other goes up and out (semi-spherical a bit)
i am looking thru the autodesk viz newsgroup search results for water at the moment
but i only need a still image so That simplifies my lack of understanding considerably
i found a Ted Boardman article so i might try to incoroporate That
any comments suggestions Ideas greatly appreciated
Randy
Alexander, Thanks i will check That out
MJL, so far i made up a cylinder, converted to mesh, subdivided
i need to fillet the top edge where the water goes over the side
but how to make a map that fits onto This is next question
Thanks for the Info and suggestions
Randy
