Revit-max
Sawyer
Started using the revit Demo last night & I really like it. A "smart" application. I would like to take the models into max. I was able to export the 3d view as a cad file but in max the normals were flipped. Seems to be the case if it comes from cad. Is there another better workflow? How smooth is this process?
Thanks
File linking works very well. Revit now has a Viz2005 plugin that allows material definitions from the revit dwg export to be read by viz. Saves a ton of time texturing your model. Unfortunety, AFAIK, the plug-in is not curretnly availible for max users.
-Z
Using File Linking, you can have the material applied to geometry entities
preserved, even after reloading.
1. Draw up a plan in Revit, open up 3D View
2. File -> Export -> DWG/DXF/DGN"AutoCAD 2000 DWG Files" as exporting file format
Export Layers File Select Revit/data/exportlayers-dwg-VIZ4.txt, then Save
3. Open Up VIZ4, File -> File Link Manager
4. Goto Presets tab, New. New Name = Revit, Format = AutoCAD Drawings (*.dwg,*.dxf)
5. Click Revit -> Modify -> Basic Tab, untick Unify Normals, click Save
6. Goto attach tab, Browse to saved 3D DWG file, click Attach this file
7. Goto Material Editor and assign Glass and Concrete materials to the Walls/Windows
Now, go back and change a few thing in Revit, eg. Add some new walls, a few more
Windows, some new doors, tear down some walls and objects too.
8. Go back to VIZ4, File -> File Link Manager, goto Files tab, select the *.dwg
Drawing, click reload. Most materials should still be kept, sometimes, Glass
and doors material won't be so you have to re-apply them using selection list.
And lastly, I think Revit and any other CAD package would have this problem with face normal flipped the wrong way, but not to worry, you can fix that in MAX by just select a few faces and flip normal.
I think it's usually not recommended to put Revit's furniture objects into your file. Well, I usually didn't. I just model the structure, the most essential bits, put the furnitures (for the plans/section/elevation) and then turn them off before exporting. To turn them off quickly and easily, goto the view properties -> visibility-> model category -> furniture. Once exported, you can import into MAX and use your own furniture libraries... which is usually better.
