Msamir Posted February 8, 2005 Share Posted February 8, 2005 Hi guys, I want to put materials on a model that was imported from autocad so the problem is when i place a material on the model the whole thing gets the material so if i want for example only a window gets the material what should i do ? in other way i cant make the model explode . So should i convert the whole model to editable poly or mesh or what should i do ? Thanks Link to comment Share on other sites More sharing options...
Tim Nelson Posted February 8, 2005 Share Posted February 8, 2005 If you have regular solids & surfaces in autocad, you need to put the different types of objects on different layers. So all windows would be on a layer, doors on a layer, etc. Then when you import to Max you will be able to assign each material according to whatever layer it's on. Link to comment Share on other sites More sharing options...
MJL Imaging Posted February 8, 2005 Share Posted February 8, 2005 what he said Link to comment Share on other sites More sharing options...
Msamir Posted February 9, 2005 Author Share Posted February 9, 2005 I'll try that , thanks for your quick reply Tim Link to comment Share on other sites More sharing options...
