Windows 3GB Switch ??
  • 2 weeks later...
I heard about Windows 3gb switch to help about out of memory problems during rendering if you have 2Gb physical ram.
Anyone using this switch ? Must have 2gb ram or lower ram can benefit from this switch ?
Thanks
sounds interesting. what is this switch? an application i should down load? is it free? i have 1 gig ram.
I found this from web sites but I like to heard from hardware gurus before I try because I don't want to mess with my stable system...
Windows® XP® Professional is required.
  • A modification of boot.ini file is needed to activate this capability at the system level. The boot.ini switch /3GB needs to be added in order to make 3GB available for user mode applications. For example:
    [boot loader]
    timeout=30
    default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
    [operating systems]
    multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional 3GB" /fastdetect /3GB
    multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect
    Notes:
    • Improper modification of the boot.ini file can cause the operating system to be inoperable.
    • For testing purposes of a given hardware configuration, it might be preferable to create several entries in the [operating systems] stanza, as documented in above example, as well as leave a non zero timeout, to allow user selection at boot time between regular boot and boot with the /3GB option; this can allow easy recovery in case the /3GB option causes a problem described in section Additional Operating Considerations below.
    • Modification of the boot.ini file requires administrative privileges.
    • Do not add the /3GB switch if running Windows® NT® 4.0 Workstation or Windows® 2000 Professional.
    http://www.hp.com/workstations/segments/mcad/dassault/windows/memory_xp.html
  • Link to comment
