hosamzidan Posted February 15, 2005 Share Posted February 15, 2005 i'm just having this problem here i it costs me a lot of time so what i'm asking about is how to make a path so that i can array an object " a tree for an example " ....... u know a path like an "S" or somthing thanx -Hosam Link to comment Share on other sites More sharing options...
anvaraziz Posted February 15, 2005 Share Posted February 15, 2005 press f1, take search option , type spacing tool .... thats it.. if u r using max 6 , right click on main tool bar , select extras, click and hold on array button, it ll drop down the menu for snap shot , n spacing tool. select spacing tool , there u can select ur path, play with the options ,,, remember to press apply before u close the spacing tool.... Link to comment Share on other sites More sharing options...
elmassry Posted February 15, 2005 Share Posted February 15, 2005 oo thanx man ..... but i ment AutoCAD ...... Link to comment Share on other sites More sharing options...
caddiellac Posted February 15, 2005 Share Posted February 15, 2005 Maybe you can do the spacing tool in max and export it to a .dwg so you can use it in autocad. Link to comment Share on other sites More sharing options...
Fernando Lino Posted February 15, 2005 Share Posted February 15, 2005 It's very easy...there are two ways: 1st you do need to create a block, after that you can use "divide" and select "B" for use Blocks ...select the path and that's it!! or "measure" if you want a specific dimension between blocks these commands are under draw>point good luck!!! Link to comment Share on other sites More sharing options...
hosamzidan Posted February 15, 2005 Author Share Posted February 15, 2005 OO Fernando i really don't know how to thank u man it's relly helpfull & it's wat i was looking for thanx Hosam Zidan Link to comment Share on other sites More sharing options...
