caddiellac Posted February 18, 2005 Share Posted February 18, 2005 Hello all, How do i extrude two rectangles to become an enclosure? and i mean extruding all at once, without having to use subtract. Tried regioning but that didnt work.. help! Link to comment Share on other sites More sharing options...
Tim Nelson Posted February 18, 2005 Share Posted February 18, 2005 That's a good question. I've received files before that have rectangular regions that have openings in the middle, so when you extrude it, you are extruding only one shape & you don't have to subrtract the middle. I've tried to figure out how to do that, but have no idea. Link to comment Share on other sites More sharing options...
Tim Nelson Posted February 18, 2005 Share Posted February 18, 2005 Ok, I take that back. I just figured out a way, but is basically just as much work... When you create your rectangles, you turn them both into regions. Then you can subtract the inner region even before you extrude. It then becomes one shape. I'm guessing that's the only way, but if not I'd like to hear otherwise. Link to comment Share on other sites More sharing options...
Fernando Lino Posted February 18, 2005 Share Posted February 18, 2005 Tim is right, region is always the best option for solids, I also use "boundary" alot for complex shapes, I draw it with lines and you pick one point inside of the shape and Autocad will create the region or polyline for you. Link to comment Share on other sites More sharing options...
caddiellac Posted February 19, 2005 Author Share Posted February 19, 2005 Thanks guys. Regioning the rectangles seperately IS a better alternative than subtracting solids for me Link to comment Share on other sites More sharing options...
