Cesar R Posted June 26, 2002 Share Posted June 26, 2002 "IDE DMA Check Version: 1.00 Download File Size: 36 KB, Date: 1/4/2002 12:24:03 PM Desciption: DMA Check - Allows confirmation on whether you have DMA enable or disabled for IDE devices in Windows NT. DMACheck also allows you to enable or disable DMA." http://www.boxxtech.com/Asp/support_miscfiles.asp I used on my machine (WD Caviar 7200) and this thing is super fast. I can really see and improvement when opening reg windows and Max scenes. check it out! Link to comment Share on other sites More sharing options...
quizzy Posted June 26, 2002 Share Posted June 26, 2002 well it doesn't work on windows 2000.... Link to comment Share on other sites More sharing options...
Cesar R Posted June 26, 2002 Author Share Posted June 26, 2002 if you go the wd website, they have something that is supposed to do the same. give it a try. Link to comment Share on other sites More sharing options...
Greg Hess Posted June 27, 2002 Share Posted June 27, 2002 You can perform this same function without a utility by doing the following... Start-settings-ctrl panel-system-device manager-devices There will be an IDE controller, right click and properties on the primary and secondary channels. You'll see device settings, thats where you can set DMA or PIO mode for all devices on the chain, just set everything to DMA, it'll auto select the correct ones, reboot and your done. Link to comment Share on other sites More sharing options...
Cesar R Posted June 27, 2002 Author Share Posted June 27, 2002 cool !, what does PIO mode do? Link to comment Share on other sites More sharing options...
Greg Hess Posted June 27, 2002 Share Posted June 27, 2002 PIO mode, roughly translated means... "SLOW AS SHI#" Its a compatability mode, from 1 to 16 megs a second. Link to comment Share on other sites More sharing options...
Cesar R Posted June 27, 2002 Author Share Posted June 27, 2002 lol, Link to comment Share on other sites More sharing options...
