esilvis Posted June 3, 2003 Share Posted June 3, 2003 Any thoughts on why 3d studio max 5.1 locks up, kicks me out of program gives me a physical memory dump (blue screen) then restarts computer. Seems to happening when loading materail palette, existing program, and just plain whenever. Running Dell dual processor, 1g ram Windows 2000 professional Link to comment Share on other sites More sharing options...
plastic Posted June 3, 2003 Share Posted June 3, 2003 it's a hardware problem. first you should check your RAM with www.memtest86.com Link to comment Share on other sites More sharing options...
esilvis Posted June 3, 2003 Author Share Posted June 3, 2003 Thanks for the responce and direction. Does the memtest fix any errors that may occur? Link to comment Share on other sites More sharing options...
xgarcia Posted June 3, 2003 Share Posted June 3, 2003 no it tells you if your ram is bad - then you replace it. Link to comment Share on other sites More sharing options...
esilvis Posted June 4, 2003 Author Share Posted June 4, 2003 Thanks for the replies. Ran memtest over night all tests on. No reported errors. Any thoughts or comments? Eric Link to comment Share on other sites More sharing options...
plastic Posted June 4, 2003 Share Posted June 4, 2003 try running chkdsk /f /r after reboot the harddisk will be checked for bad sectors. damaged harddisk could be another reason for crashes when opening large files... Link to comment Share on other sites More sharing options...
