Loft question
markf
I'm having trouble lofting a crown mold shape around a gabel roof path.
the loft shape is correct on the eave edge but when it turns and goes up the gable the shape rotates to ab incorrect/"flat" orientation.
Can anyone help identify what I'm not doing correctly? Thanks in advance for any help.
File attached Max7
File attached Max7
can you re attach the file its corrupted
That's odd that it appears corrupt. I can open from the CGA site no problem. Also I posted this in the Discreet Max forum and it has been looked at there.
I have re-attached the file. This time I zipped it with the Max archive function.
You can see in the front viewport that that the crown molding sahpe is rotated out from the fascia. You can see in the left viewport that is not rotated out but incorrectly flat against the fascia. This is the problem I can't seem to overcome with my loft.
Thank you for your attempt to check this out!
Any help much appreciated
