Network render avi file
DrunkenMonkey
Hi
I have set up a network and connected seven machines. They can all read each other fine and connect no problem.
When i did a test render of 50 frames as jpegs each machine was assigned a seperate frame and they all appeared in the destination folder fine.
The problem is when i try to save as an animated file such as an avi file only one machine does all the work and the others remain idle. How do i get the other machines to 'get busy' and render seperate frames that then come together as one completed avi file?
Are you sure this can happen, why don't you save it as a sequence of images and then make an avi file. Even if it can happen, making an avi file directly could sometimes be a disaster if something wrong happes in the mean time and the mashine stops for example.. (it has happen and everything was lost..)
